SAGEMCOM FAST 5364 Wifi Issues
rabuk
Message 10 of 10
I have been experiencing problems with the stability of the Wifi connection on my SAGEMCOM FAST 5364 router. The connection either slows right down or fails completely at times. Wired internet access is always fine.
I have read other posts mentioning WIFI optimisation causing problems on this router. Firstly, what does Wifi optimisation actually do, and if this is what is causing my problems could you switch it off please?
Regards.
9 REPLIES 9
Message 1 of 10
How has the connection been since your last post?
Message 2 of 10
No problem. We'll check back in with you at the end of the week to see how you're getting on.
Thanks 🙂
Message 3 of 10
Hi.
The connection has been better I think but maybe too early to be sure. I have also changed the 2.4 GHz Wifi channel number so that it does not interfere with other nearby Wifi signals.
Message 4 of 10
Hi rabuk
How's the connection been over the weekend?
Message 5 of 10
Hi rabuk
No problem 🙂
No you don't need to reboot the router.
Thanks again.
Message 6 of 10
No.
Message 7 of 10
Thank you. I'll see how it goes.
Does the router need to be rebooted?
Message 8 of 10
Hi rabuk
I have switched the WIFI optimisation off as requested, please let us know how the connection compares.
Message 9 of 10
Wi-Fi optimisation. When this is enabled, as it is by default, it has the power to override any Wi-Fi configuration changes that I might suggest that you need to make. This will not help rectify this type of problem if Wi-Fi Optimisation is allowed to change my suggested settings.
The next stage involves sending out a guide to you to help you get me some important diagnostic results so that I can analyse them for you and recommend changes to your router configuration to solve them.
