Segemcom FAST 5364 - Port forwarding
bony123
Message 7 of 7
We are having issue adding a port forwarding rules.  it says "Operation could not complete, something wrong happed"
on the LAN/DHCP setting, If the subnet is default (192.168.1.0/24) it works. But If we use any other subnet eg 192.168.198.0/24 it comes up with that error. Can someone help please
6 REPLIES 6
Message 1 of 7
Strictly speaking, this forum is only for residential customers only, for all business support, please visit:-
https://supportcentre.talktalkbusiness.co.uk/home
However, I will try & help you. From your description, I assume that you trying to change the router's IP address? Depending on your current firmware & the business versions of this router use different ones to the residential router. Have you tried doing it like this:-
  1. Remove any DHCP Reserved IP addresses
  2. Change the DNS address handed out by DHCP
  3. Change the router’s IP address & DHCP IPv4 Pool Start & End ranges to match.
Thank you.
bony123
Message 2 of 7
I have updated the details and we are business customer
Message 3 of 7
Hi bony123,
Thanks for updating your profile, are you TalkTalk business customer or TalkTalk residential?
bony123
Message 4 of 7
Morning I have updated the profile as requested
Message 5 of 7
  • Name
  • Telephone number
  • Alternative contact number
Gliwmaeden2
Message 6 of 7
Please add your Talktalk landline number to your community forum profile, @bony123.
Go via your avatar/name; settings; launch profile wizard.
Staff reply Monday to Friday. Please look out for their reply.
