26-09-2023 02:44 PM - edited 26-09-2023 07:43 PM
Hi everyone,
My Sonos system is repeatedly (some time after I restart my Win 11 laptop) unable to find my media server. Sonos suggested that it's because both my wireless bands have the same SSID and password and that I need to separate the bands. How do I do this?
Thanks, Ted
The router is a TalkTalk Hub SG4K100174
on 28-09-2023 06:25 AM
Glad to hear Keith put things right for you 🙂
on 27-09-2023 10:04 PM
Glad to hear it is all OK now.
on 27-09-2023 05:39 PM
Hi Michelle, Keith's suggestion worked like a dream. I've also managed to update the WiFi settings on my printer so that it can cope with the new SSID. No problems today with my Sonos system so I think everything is fine.
on 27-09-2023 06:39 AM
Hi TedKy,
Thanks@KeithFrench. Please let us know how you get on.
Michelle 🙂
on 26-09-2023 11:35 PM
Thanks, Keith.
I'll have a go at it tomorrow after some sleep.
Ted
on 26-09-2023 09:53 PM
OK, you have either the Sagemcom FAST 5364 or 5464, but they are the same as far as this is concerned.
The SSID (network name can be changed here for the 2.4GHz band:-
Dashboard > See Wi-Fi Settings > Manage Advanced Settings > Wi-Fi 2.4Ghz gear icon > Basic
Repeat with a different name on the 5GHz band:-
Dashboard > See Wi-Fi Settings > Manage Advanced Settings > Wi-Fi 5Ghz gear icon > Basic
However, I think it is far more likely that your problem is caused by Wi-Fi interference, with which I can provide a lot of help. I have had this quite a few times with these devices.
Let me know how you get on with the name change first though.
on 26-09-2023 07:47 PM
Router is Talktalk Hub SG4K100174
Thanks for picking up the question
on 26-09-2023 02:45 PM
Which make/model of TalkTalk router do you have, they are all different?
