Streaming interference on full fibre
ttrps
Whizz Kid
Message 17 of 17
Hi. We recently moved to full fibre (FFTP). It generally works OK, but when I stream TV on my old laptop (2008 build, Windows 10) I get a sort of electronic interference sound every now and then. Does anyone know a way to sort this out please? Is it an issue with the wireless adapter in the old laptop? Many thanks
16 REPLIES 16
Message 1 of 17
OK. Thanks Keith. I'll have a think about it.
Message 2 of 17
Well, I have hardly looked more than a few lines down the first output to see the problems. The WiFi card only supports up to 802.11g, which is ancient. Today's standards go up to WiFi 7 (802.11be), but WiFi 6 (802.11ax) will be fine, I would not like to say if it is worth getting a USB WiFi 6 adapter or not, because I dare say that the laptop must be very old as well. This would make the operating system out of date & insecure.
The only advice I can responsibly give is to get a new up to date laptop.
Message 3 of 17
Personal spec of wifi card removed.
Message 4 of 17
Message 5 of 17
Message 6 of 17
Search for cmd, open it then enter those commands one by one pressing the Enter key after each one.
Message 7 of 17
Thanks. I'm not sure how to do that. I go into Start>Run and key that in then press OK, but the pop up window instantly disappears.
Message 8 of 17
I can't find the specifications of the laptop. In a Windows command prompt, please can you issue these three commands & get me the output:-
netsh wlan show drivers
netsh wlan show wirelesscapabilities
netsh wlan show interface
Message 9 of 17
Yes it is
Message 10 of 17
Windows 10 on a Dell Studio 1737 laptop bought in 2008. It just uses Windows Security - I've not downloaded anything else.
Message 11 of 17
Hi @ttrps
Assuming you are on FullFibre 150, a download speed of 140Mbps is not your problem. It must be the laptop, especially as it is OK with your tablet nearby. You say this is old, what version of Windows is it running & what security software is installed? What model Dell Studio is it?
Message 12 of 17
Hi ttrps,
When you say that you get speeds of 140Mbps is that running the speed test on the old laptop?
Message 13 of 17
And I don't get the problem if I watch the same thing on my tablet in the same location.
Message 14 of 17
Thanks Keith. I'm using the eero router and a Dell Studio laptop. I rarely get the problem when watching youtube, but fairly constantly when watching streaming TV from places like iPlayer etc. On fast.com it shows speeds of around 140 Mbps.
Message 15 of 17
Hi @ttrps
@Anonymous has asked me to help you with this. Whilst it might be an issue with the network card, it could be a wireless reception issue as well.
What make/model of router & laptop are you using?
Message 16 of 17
Do you have any suggestions please @KeithFrench ?
