TV
Dwdotty
Message 3 of 3
I am having lots of spasmodic interferance on my TV occuring later in the day that gets worse the longer the tv is on, it also distorts the sound.
Also when I turn the TV and Talk Talk button off on my remote the blue talk talk button keeps flashing and will not stop until I take the battery out of the remote, any ideas anyone?
Message 1 of 3
Can you try a maintenance reset of the box here : https://community.talktalk.co.uk/t5/Articles/TV-Box-Maintenance-Reset/ta-p/1429347
Set the box back up and see if the issue continues.
Message 2 of 3
Which box do you have?
What is the picture like if you plug the aerial into the TV, bypassing the box? Does the TV picture show similar symptoms over a similar period?
The weather is also causing issues at the moment. Has this been going on long, or maybe just the last couple of days?
