Weak Wi-Fi keeps dropping
Jonem
Message 10 of 10
Hi - I have tried twice through online chats to resolve Wi-Fi dropping issues, buffering on tv and slow tv app loading without success. I have requested a replacement for my quite old router but have been told a Wi-Fi booster & extender will resolve the problem.  I have bought one from Argos and it has made no difference at all.  I see other community members have the same issue and they have had new routers sent out promptly so why have I been told I will have to pay for a replace t?
9 REPLIES 9
Message 1 of 10
Hi Jonem
Message 2 of 10
Hi Jonem
Message 3 of 10
That would be great - I think it’s the only
option left to try. Thank you for listening and making an effort to resolve  my issues.
Anonymous User
Message 4 of 10
Hi again,
I can send a replacement router (wifi hub) to see how this compares, would this be ok?
Message 5 of 10
Huawei HG633
Anonymous User
Message 6 of 10
Which router are you currently using please? (make and model)
Message 7 of 10
I have not received a response yet. I would appreciate a reply please.
Anonymous User
Message 8 of 10
Good morning,
How are you getting on?
Chris-TalkTalk
Message 9 of 10
Hi Jonem,
I'm sorry to hear that you are experiencing problems with your service. Line test is passing, sync speed looks good and connection looks stable. Is it only devices connected to your router by wifi that are affected? Do you have any devices connected to your router by Ethernet cable?
Anonymous User
