Weak signal
daz45
Message 7 of 7
The Router Is located at the front of my house,
Wifi throughout the house Is fine sometimes lose connection In the back of the house .
but The connection does not seem to reach the garden .
what would be the best way to solve this ?? Powerline adapter I see Talk Talk provide one but see no where to purchase or price . Unless I am missing something
6 REPLIES 6
Message 2 of 7
Hi @Debbie-TalkTalk
I am waiting to see if this customer still requires my help.
Message 3 of 7
Thanks for your help @KeithFrench
Hi daz45
KeithFrench is one of our valued Community Stars and can help with a range of issues related to wireless and networking. At times he may ask you to send him test results via a Private Message to help analyse/diagnose an issue.  Although Keith does not work for TalkTalk, he very kindly shares his time and knowledge to help with others.  If you need further help or, if we need to take any details such as personal information about your account like phone numbers, account numbers etc.  one of the TalkTalk team will jump in and help out.
Message 4 of 7
IT possibly might need a booster, but there are other things worth considering first, that will not cost you anything.
Have you had TalkTalk’s Wi-Fi optimisation disabled on your Sagemcom FAST5364/5464 router? When this is enabled, as it is by default, it has the power to override any Wi-Fi configuration changes that I might suggest that you need to make. This will not help rectify this type of problem if Wi-Fi Optimisation is allowed to change my suggested settings. Only TalkTalk can do this for you, you cannot do it yourself. If not, just request they disable this for you in your reply.
daz45
Message 5 of 7
Thanks Keith
I have the Sagecom - Fast 5364.  3tb
the one with the big copper coloured plate behind the plastic holes
Message 6 of 7
Which make/model of router do you have?
