5GHz unstable. 2.4GHz is fine.
on 11-04-2024 02:29 PM
Message 7 of 7
Router: Sagemcom-FAST5364
Ive had to separate my networks and the 5GHz connection keeps dying - briefly.
I’ve moved most of my devices onto the 2.4GHz one.
I’ve tried different channels and there are no physical obstacles nearby.
Any ideas?
Geoff
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
6 REPLIES 6
on 15-04-2024 09:14 AM
Message 1 of 7
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 15-04-2024 09:05 AM
Message 2 of 7
Currently, I am waiting for the customer to reply to me.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 15-04-2024 07:16 AM
Message 3 of 7
Hi gdm2905
Sorry for the delay.
KeithFrench is one of our valued Community Stars and can help with a range of issues related to wireless and networking. At times he may ask you to send him test results via a Private Message to help analyse/diagnose an issue. Although Keith does not work for TalkTalk, he very kindly shares his time and knowledge to help with others. If you need further help or, if we need to take any details such as personal information about your account like phone numbers, account numbers etc. one of the TalkTalk team will jump in and help out.
Thanks @KeithFrench
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
12-04-2024 02:53 PM - edited 12-04-2024 02:54 PM
Message 4 of 7
I would need to see these other views from your WiFi analyser like:-
- 2.4Ghz channels
- 5GHz channels
- signal/strength over time graph (having been running for 5 mins before taking the screenshot)
to have any idea. However, is this nirsoft application a WiFi analyser?
I can see that you are using the TalkTalk D-Link WiFi extender, there is a firmware bug with these, where the throughput of both WiFi bands will slow right down. Currently, though I can't tell anything from your screenshot, as it is just an AP view.
For any other screenshots I would suggest that you PM them to me (to preserve your privacy) any one in the world can see that one.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 12-04-2024 01:53 PM
Message 5 of 7
I've attached a screenshot showing channels. (In red rectangle).
My router is providing four different "networks" - not sure why they are under D-Link company name?
One of them is very poor quality.
Do you think removing WiFi Optimisation will help?My networks - in red rectangle.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 12-04-2024 10:47 AM
Message 6 of 7
This can be down to the location of the router, if it is near electrical items, or it could be down to WiFi interference.
Have you had TalkTalk’s Wi-Fi optimisation disabled on your Sagemcom FAST5364/5464 router? When this is enabled, as it is by default, it has the power to override any Wi-Fi configuration changes that I might suggest that you need to make. This will not help rectify this type of problem if Wi-Fi Optimisation is allowed to change my suggested settings. Only TalkTalk can do this for you, you cannot do it yourself. If not, just request they disable this for you in your reply.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Related Content
