Wi-Fi not in every room
Millycat22
Message 16 of 16
Since getting fibre 65 which has to be on an outside wall, Wi-Fi doesn’t work well in some rooms. We are in a bungalow so would expect the Wi-Fi to extend to the whole house? Please can you  advise how we can rectify this?
15 REPLIES 15
Message 1 of 16
You're Welcome 🙂
Message 2 of 16
Thanks Karl
Message 3 of 16
A Wi-Fi booster has been ordered for you.
Message 4 of 16
Hi Michelle
That’s great, yes please!
Anonymous User
Message 5 of 16
Hi Milly,
We would send this free of charge.
Message 6 of 16
Hi Michelle
how much is the booster?
Anonymous User
Message 7 of 16
Hi Millycat,
Would you like us to send you a Wifi Booster?
Message 8 of 16
Hi @Millycat22 @Anonymous
I cannot help you as it transpires that none of your devices support any WiFi analysers. In that case, the best that I can suggest is the Sagemcom FAST 266 WiFi Booster. The name does not do it justice though, as it combines with your current router to form a mesh network.
Message 9 of 16
Hi @Millycat22
Some iPhones do have problems with the 5364, but I'll address that for you.
Do not worry about interpreting the results, I will do that for you. I will send a PM to you that contains a link for a guide of mine on Wi-Fi interference. It is quite long (about 30 pages), but you will probably only need to look at three or four pages in total. Initially look at the section called "Are you suffering from interference – prove it first". This is the first link in the table of contents. This section includes full details of free Wi-Fi analysers that I recommend for Windows, Windows phone, Android and Apple operating systems. However, I have no way of testing the Apple product. Select the analyser of your choice & my guide explains how to use it.
If you are using Wi-Fi Scanner, then please attach the zip file to this thread. As soon as I have downloaded it, I will remove the attachment from your post, to preserve your privacy.
Please post the screenshots to me in a PM (to protect your privacy), which I have requested in my guide. No photos please as they can be difficult to read, because the text can get out of focus when zoomed in. Please ensure that the analyser window is maximised (if Windows) before taking the screenshots & upload them via the "Insert Photos" button (in a mobile browser it's the picture icon) on the post editor's toolbar with the Size parameter set to Large.
Message 10 of 16
Hi Keith
Yes that would be very useful thank you.
my iPhone also has issues only when in the house where it looks like it’s connected to the Wi-Fi but sometimes when you try going on the internet or WhatsApp it just says it’s connecting and I have to toggle the airplane mode to get it back. I’m not sure if this is related to our signal problem.
Message 11 of 16
Hi @Millycat22
@Anonymous has asked me to help you. I can provide impartial help to sort out what is causing the problem and what will be the correct resolution.
Message 12 of 16
Hi Michelle
i am using Sagecom fast 5364-3 TB
Thank you
Anonymous User
Message 13 of 16
Thanks for your post. Which router are you using please? (make and model)
@KeithFrench - would you be able to offer any advice please?
Message 14 of 16
Thank you!
Divsec
Message 15 of 16
Hi @Millycat22 a WiFi extender or mesh is the answer, but TT will be able to better advise tomorrow when they return.
your post has been escalated and you should hear soon.  In the meantime please check your community profile and add your landline number and/or account number so your account can be identified. Please don't post personal information here.
Anonymous User
