Router
Pops58
Message 11 of 11
My router will not support mobile Internet calls on fibre 35
10 REPLIES 10
Message 1 of 11
Thanks for help all.  If wifi calls don't give me better signal in my home then O2 is out in 2025
Message 2 of 11
@Pops58 thanks for raising this. It made me check my network again and the issue with Lebara is over.
A quick toggle as suggested and both mine and my wife's phone are now set up.
Message 3 of 11
Yes, correct, @Pops58 :
If you look in recent calls on your mobile, each call should show listed with a wifi symbol too in your records, when it's been working properly.
Message 4 of 11
This has changed something.  I Now have a new symbol after the number called as 3 arced lines on the right.   Is this the wifi symbol?
Message 5 of 11
Could you toggle to flight mode on your mobile device and then try WIFI calling again please?
Message 6 of 11
There's very small print on a sticky label either very low down on the back (for much older models) or behind the pull out tag that shows your wifi password etc, near the top.
Magnifying glass likely to be needed, seriously, @Pops58!
Message 7 of 11
There was a spell in the autumn when the Sagemcom router software messed up wifi calling. That firmware update had to be rolled back for affected customers.
Supposed to now be fine.
Pops58
Message 8 of 11
Yes no wi fi calling
Hiw domI identify my router?
Message 9 of 11
Which mobile network are you with as not all networks have internet calling available due to licensing issues.
For example, I'm with Lebara and they do not have the facility.
I'm doubtful that a router per se would block this function, but other factors such as VPN might.
Does it work on other WiFi networks?
Have you tried a forum for your phone and model number to see if others have the issue and maybe found a solution?
Gliwmaeden2
Message 10 of 11
You mean you can't get wifi calling?
Which router have you got, @Pops58?
Please complete your community forum profile details for Talktalk staff to identify your account. They'll reply during the day during the week.
Go via your avatar; settings; drop down menu. Complete Personal Information. Scroll down to find the button to SAVE CHANGES.
