Working DynDNS (DDNS / Dynamic DNS) free service for TT Wifi Hub (Sagemcom)?
psdie
Message 4 of 4
Grr - I'm back to trying to find a working Dynamic DNS option on the Wifi Hub.  I hope someone can suggest a working free option.
Originally I believe I used the built in ZoneEdit support (from the DynDNS page) but this stopped working because ZE dropped support for username/pass in favour of a token.  I then switched to updated ZE via DNS-o-matic, which was supported by Wifi Hub, but that stopped working in Jan.
I then switched to a Windows client ZoneEdit DynDnsClient, which is very fiddly because you have to compile yourself (.NET C#), but worked until recently, then started failing without warning in August ("The remote name could not be resolved: 'dynamic.zoneedit.com'" and similar errors).
Is there really not a working free DynDNS service option on this router?  🙄
3 REPLIES 3
Message 1 of 4
Dns-o-matic hasn't worked for ages. With the Sagemcom, your best bet is the free version of No-IP, OK you have to keep the domain active every 30 days, but it does work well.
psdie
Message 2 of 4
Hi Keith - it's the Sagemcom. There's free options listed on the DynDNS page, but per my post both ZoneEdit and DNS-o-matic no longer work.
Message 3 of 4
Which Wi-Fi Hub are you using, the Sagemcom or the Huawei, both of which do support at least one free DDNS service that works.
