downloads speed has dropped to 10mbps
moorlander
Super Duper Contributor
Message 24 of 24
good morning everyone and A happy new year to all.
All has been going well until yesterday when I returned home ..Noticed that my internet speed was extremely low. I am on fibre 65 with copper cable from cabinet to property ( OPEN REACH have missed us off the national network upgrade as all our lines are underground and will not upgrade until individual customers request this  - long story for another time  )
Download speed is usually around 55mbps which is ample for our family and work purposes . Yet noted that is was now 10mbps yet the uploads speed was around 15mbps. I undertook speed tests via talktalk speed test and via OOKLA separately ...Both indicates no issues with PING or LATENCY yet showed that my downloads speed was around 10mbps.
I reported this via talktalk webpage and was advised there was a fault on my service...which I thought GREAT !! it would be sorted out overnight..How wrong I was....checked back this morning having received a text message advising there was no fault found and after checking again via the talktalk support page endued up on chat service ....and after an hour or so was advised that an engineer would be required ....only after been told to remove the open reach socket ....check all my devices ( all disconnected for testing and no issues found ) multiple lines tests...router reboots...rooter power off and on several times ...more reboots.....
I cant understand why the uploads speeds are unaffected and PING and LATENCY are also unaffected yet downloads are very low speeds....
Do talk talk throttle back ''unlimited'' fibre?
We only watch tv now via the internet and it has taken a hammering over Christmas yet not to a massive degree...
So engineer coming tomorrow...not sure who as talktalk agent would not give me the company name ( so much for security etc - will probably by MJ QUINN bit it would be nice to know )
and I did get the standard ..''if we cant find anything you will be charged £75'' ...
has anyone else experienced speed issues lately ?
Surfing from The Independent Republic of Yorkshire
23 REPLIES 23
Message 21 of 24
Hi moorlander,
Are you experiencing any problems with your telephone service, any noise on the line?
Message 22 of 24
Hi Debbie . Everything has been in for quite a while now … until yesterday.
 On instruction of the chat service agent …. I plugged the router into the test socket and undertook several reboots and power down / ups which had no effect . Still slow download speeds yet uploads , PINGS and latency are what they were prior to having problems … and they are still ok.
there has been no changes to the set up, no cabling changes and no additional devices ( I disconnected all wired devices and turned off all WiFi connected devices to check and the speed test was the same as they were connected )
I have had no drop offs / disconnections and the light on the hub router has remained solid white
Message 23 of 24
Hi moorlander
The line test is clear but I can see a high number of re connections on the line and this will affect the sync speed.
Has the connection been dropping or has the router been rebooted?
Is the router at the test socket at the moment?
