eero 6 where to plug phone
shaking
Message 6 of 6
i just installed my eero 6  which is working great but no where to plug my phone in i found i need a Grandstream Digital Voice Adapter where can i get one i thought it would have come with the eero.
thanks
Gary
5 REPLIES 5
Message 1 of 6
Hi @shaking
Unplug the Grandstream & connect an Ethernet cable from that port on the eero to the network switch. Then connect the Grandstream to one of the other ports on the switch, along with any other Ethernet devices that you want.
Message 2 of 6
Hi shaking
Thanks for the Private Message confirming the voice adapter has arrived 🙂
Message 3 of 6
How are you getting on? Has the adapter arrived?
Message 4 of 6
Hi shaking
Apologies for this.
I've ordered the digital voice adapter for you, please allow 48hrs for this to arrive.
Gliwmaeden2
Message 5 of 6
Did you include VOIP (continued use of your Talktalk phone number with a full fibre service) at the same time as the order for Full Fibre, @shaking?
If so, staff should be able to get a DVA sent out to you.
If not, it's not possible to add it later with Talktalk.
Add your account number in Personal Information for staff to identify your account. Go via your avatar; settings; drop down menu....complete the details and scroll down to find the button to SAVE CHANGES.
Staff will respond during the day.
