netgem 4k
kyberboy
Message 2 of 2
i cannot access my settings on my netgem4 box
glewis
1 REPLY 1
Message 1 of 2
You cannot access or cannot find?
To find them, they are in the scroll bar at the top of the home page. Select the home button (house), then use the up arrow, then the left button and they should become visible.
If you can't access them, then reset the box by pushing the power button on the left hand side of the box 5 times when the box is on.
Hope this helps.
