New 4k Box
BowBelle
Message 7 of 7
Hi have just received the new NetGem 4k box to replace our existing one. Can someone tell me does this box record all programmes not just the currently viewed one and will recordings from our existing box be saved and available to view through the new box. Not had any response via TalkTalk help so far
6 REPLIES 6
Message 1 of 7
Thank you for the support @fr8ys
Message 2 of 7
@BowBelle don't forget to request the entertainment monthly charge is removed from your account.
Message 3 of 7
No worries:) Thank you very much for letting us know. Should you require any further assistance, please do not hesitate to contact us. Thank you very much for contacting TalkTalk. Have yourself a lovely day ahead.
Goodbye
Message 4 of 7
Thank you so much. I’ve decided to return the new box and keep my original one as it does everything I want.
nambuso-TT
Message 5 of 7
Hi there
@fr8ys Thank you very much for the support.
Message 6 of 7
You say it's a NetGem box, which is unusual now as TalkTalk have not supplied this box for somewhile now. The only box they offer now is the TV hub which does not record.
If it is a NetGem box, then recording is via a USB you insert into the box in the rear panel. The box only has one tuner and so will only be able to record the programme you are watching or record 1 programme if the box is in standby.
If you wish to record a programme while watching another, you will need a separate aerial feed to the box and TV and watch a programme on the TV, while the box is on standby.
You cannot view any programmes recorded on another box via another box, even if it is the same model due to licensing issues imposed by the various TV companies.
Hope this answers your queries.
