video is slow to load fibre 500
Stevio777
Message 4 of 4
Hello When I first had Fibre 500 it was pretty good but for the past few months it generally is now slow to load a film I've checked the speed and that is fine? But now video is slow to load and keeps buffering!
thanks,
Steve
3 REPLIES 3
Message 1 of 4
are the adapters direct into wall sockets?
Have you tried relocating these to other sockets to see if the performance changes?
Stevio777
Message 2 of 4
Yes it does. But I am using a plug-in and the TV is hard wired with a Ethernet cable from that.
PS at first it was no trouble and the bar that shows you it's loading up was streaking across the TV
Message 3 of 4
I'm sorry to hear this. Can I just confirm, does the buffering also happen if you connect wired?
