2 Mbps download speed on Full Fibre 500 (CityFibre)
Chris211
Message 12 of 12
For the last couple of days my download speeds have been very low (1-3 Mbps) but the upload speeds have been normal (450+ Mbps). I have tried restarting the ONT and the router and have also tried using both 2.4 and 5Ghz wifi and I get slow speeds on both.
The router is WiFi Hub Sagemcom FAST 5364 and the firmware version is SG4K100136.
11 REPLIES 11
Message 1 of 12
I'm glad to hear this and thanks for confirming.
Chris211
Message 2 of 12
The fibre service is back online now and the speeds are also back to normal.
Message 3 of 12
OK, thanks for the update. I'll check in with you tomorrow to confirm that everything is OK
Chris211
Message 4 of 12
I called and the full fibre technical support team said that there is currently network maintenance in my local area and it should be finished by 6pm today.
Chris211
Message 5 of 12
There is 4 green static lights on the ONT. Power, broadband, service and ethernet are all green.
Message 6 of 12
OK thanks, which lights are currently on, on the ONT?
Chris211
Message 7 of 12
Still no internet connection after powering down the ONT for 30 minutes. I also tried factory resetting the router and that also did not help.
Message 8 of 12
Hi Chris,
OK, please let us know if there's any improvement following the 30 minute power down
Chris211
Message 9 of 12
I now have no internet connection. I will try powering down the ONT for 30 minutes. I don't currently have any wired device I could plugin directly into the ONT to test it.
Message 10 of 12
I'm sorry to hear this. What speeds are you seeing if you run a wired speed test directly at the ONT? Did you also try powering down the ONT and the router for a full 30 minutes and then retested this again?
Message 11 of 12
What happens if you connect a wired device via an Ethernet cable directly to the ONT, in place of the router and do a speed test from there?
