Constant solid orange light
Mycjets
Whizz Kid
Message 53 of 53
Hi.
Today my router shows a constant orange light. No connections possible. Reset, left for several minutes, rebooted still same problem. Checked all cables and connections. Unplugged then and popped back in. Rebooted, still same problem. Requested a line check via talk talk, states no issues.
Really stuck now and need to get back online a quicky.
Any support greatly appreciated.
N
52 REPLIES 52
Message 21 of 53
I'll do another factory reset now.
Message 22 of 53
I did all this yesterday. Factory resets etc. Why do it again?
Message 23 of 53
A factory reset is required on your router which will restore the router to it's original settings, including the Wi-Fi Network name (SSID) and password.
If the password has been changed, please refer to the one on the stickers attached to your router to find the original password.
Once the No Internet connection issue is resolved, I can assist you in reconnecting to the network.
Message 24 of 53
Thank you, A line test has not identified an issue outside your premises. As you've not made any changes before this issue started, the next step is to look at the router.
I'll guide you through the router checks - ensuring it's up to date and addressing any potential temporary issues that could have caused the disconnection from the Internet.
If these steps don't resolve the issue then I'll look at other potential causes.
Message 25 of 53
No nothing at all.
Message 26 of 53
Thank you, Have there been any recent changes in your home that could have impacted your service?
For example - new or replacement equipment, building work on the premises or damage to any wiring in or around the home?
Message 27 of 53
Yes. White light showing.
Message 28 of 53
You should be able to see the power light on the front of the router.
If this light is on, your router is receiving power.
Just to verify, is the router currently powered on?
Message 29 of 53
yes, though router says connected
Message 30 of 53
@Mycjets I can see that your Internet connection is currently offline.
This means that your Internet, WIFI, Email or TV Service will not work properly.
Shall we fix that now?
Message 31 of 53
A line test is currently underway. This checks the equipment used to provide the broadband service to your home - including the exchange, cabinet and line equipment.
This can take up to 5 minutes to complete. I'll let you know if this test finds a fault, otherwise I'll continue with further checks.
Message 32 of 53
Thank you @Mycjets I am about to run a test that will look at the condition of your line. This test will identify any faults in the cables and associated equipment, between your home and the exchange, that could effect your service.
The result will allow us to determine if an engineer is required, or whether additional checks need to be completed with you.
Message 33 of 53
I have no medical equipment that needs the internet and I can make calls.
The router has gone orange. I assume that's you?
N
Message 34 of 53
Thank you @Mycjets and I understand however, we will need to run checks 1st, Will you (and anyone who lives with you) be able to contact emergency services while your services remain impacted?
Message 35 of 53
What is the recommended replacement router now as this I have is a very old type? Had it years.
Message 36 of 53
I did say it did drop out earlier. 🙂
Message 37 of 53
no
Message 38 of 53
@Mycjets As you have confirmed that the internet is not dropping at the moment and experiencing slow speed, I will run checks for slow speed.
Do you have any active monitoring for life threatening health reasons which is solely dependant upon your TalkTalk Broadband or Telephone line?
For example a care alarm, lifeline, health pendant or fall detector.
Message 39 of 53
Did drop earlier.
Stable now, speed not great. I'm sat next to the router now.
Message 40 of 53
Perfect! Please confirm the issue you are experiencing at moment with your router, no internet, slow speed or dropping connection?
