Device FAST 5364-3,T8 Keep stopping working but shows white light
sparky161
Message 6 of 6
My router seem to be having issues since Friday, every few hours, it stops working, however the white light still shows on? i have had to turn off the power to get working again, even gone as fars as complete reset, but happened again, can you suggest a fix please, or send out a replcement router?
Regards - Mark
Mark
5 REPLIES 5
Message 1 of 6
Hi sparky,
We now have an update on this - Update 8:40PM  December 17th 2024 - Our team are in the process of applying a solution to all impacted Wi-Fi Hubs and aim to resolve this by tomorrow morning.
sparky161
Message 2 of 6
Hi Karl, seem to of been better, but has stopped couple of times, the strange thing is the Dns settings i had applied have now reverted.
Also the Hub interface seems to be very glitchy? e.g press a button and sometimes does nothing, and couple of time just returns to login screen?
Do You have any other suggestions, im currently WFH 3 days a week, so heavly rely on Internet for my daily job
Service with Talk talk, has been very good, but last week has really been a bit of a let down
Mark
Message 3 of 6
Thank You
sparky161
Message 4 of 6
Hi Karl, i have set as below, as a note i dont see (Make sure ON is enabled)
Will see how things are over next day or so
Mark
Message 5 of 6
Can you change the DNS Settings in your router to use Google DNS, and test this over the course of the day to see if this resolves the connectivity issue where the router light remains white.
Please report back if this does help as this will aid our investigation.
Change your router DNS settings to use Google DNS.
  • Open your web browser, type http://192.168.1.1 into the address bar and press Enter
  • Enter the username admin (in lowercase) and password (you'll find this on the removable settings card on the back of the Hub, and select OK
  • Select See internet settings
  • Select Manage advanced settings
  • Select TalkTalk WiFi Hub
  • Select DNS Tab
  • Make sure ON is enabled
  • Add Primary and Secondary DNS Servers ( Primary = 8.8.8.8  Secondary = 8.8.4.4 )
  • Select Apply
Please note ;  If you currently use any Homesafe services such as Homework Time etc.  This will not work whilst you have the DNS set to Google.
