EERO coverage and Wifi Hub 2 adaptor
sherifuro
Message 2 of 2
Hello ,
I got EERO router recently as part of the Fiber 150 plan . its coverage is not like the Wifi Hub 2 . it is poor . it needs extender . TalkTalk only offers the whole Wifi Home system to extend the coverage and it will cost extra pounds every month.
I tried to return back to the Hub2 but unfortunately , it has a problem with the power adaptor , I do not know the problem what the power light is not turning on when I connect the adaptor to the wall socket .
I made sure that the socket is working with other plugs .
my question ,
Is there any way to get the extender alone (EERO extender) without the whole home system ? if not , could the Hub2 be replaced with another working one or got fixed ?
1 REPLY 1
Message 1 of 2
Yes, you can contact the Loyalty dept on 0345 1725157 for extra Eero nodes.
