Eero 6 and Goggle nest
Natzhew
Message 2 of 2
Hi everyone
I received an Eero 6 a few days ago and since installing it I've had issues with my Goggle Nest app. The thermostat is connected fine to the WiFi and I can connect to the Nest app fine if I'm using WiFi on my phone. But if I'm using mobile data, whether home or away, I can't connect to the Nest app. It must be the Eero blocking outside devices from controlling devices on the network but I've no idea how to get it to work.
1 REPLY 1
Message 1 of 2
You would need to configure port forwarding to allow a connection from the internet to a local device. You will need to find out what TCP or UDP ports that you need to forward & I can help you from there.
