on 22-07-2024 09:45 AM
I know it’s a previous topic of discussion and unresolved issue regards reduced signal strength experienced when upgrading to Talk Talk full fibre and using the Eero device.
like others I’ve had to install an extender to restore service to some of my device locations. However the extender is subject to high interference from neighbours devices which are also using Ch1 for 2.4Ghz
I read somewhere the Eero device automatically optimises channel, but this obviously isn’t the case as I have an app where shows a number of networks in proximity also using same Chanel, whilst there are others with no networks.
how do we feed this back to Eero to address this type of limitation along with increasing signal strengths ?
on 19-08-2024 08:24 AM
Hi Dave,
I'm sorry to hear this. Did you purchase the additional eero? Would you like us to send a returns bag?
on 18-08-2024 04:22 PM
on 25-07-2024 01:18 PM
Good afternoon Dave,
How are you getting on?
on 22-07-2024 10:30 AM
I can offer extended WiFi diagnostics in this situation.
However, other factors should be investigated first. When this happens, what is the status displayed in the app for the internet connection? Do you have any wired connections & if so, how do they perform?
Whilst the eero is supposed to manage Wi-Fi interference, if this is very bad, particularly in the 2.4GHz band, then it cannot do anything about it, no router can. The same goes for any router at that point. Other things that may then need to be investigated are its location within your property and the WiFi bands that you use.
on 22-07-2024 10:06 AM
OK thanks. I've checked and signal strength to all devices looks fine. Are you currently experiencing problems?
on 22-07-2024 09:58 AM
Done
on 22-07-2024 09:50 AM
Hi Dave,
We'll then look into this further. Please do not post this information on this thread. Once you've updated your profile please post in your topic to confirm it's updated.
