Eero Ad Blocking
leebitton
Message 8 of 8
I have had an Eero router for over two years now but it seems I may have somehow enabled ad blocking. I cannot see how to turn it off again and when I search online to says about going to the discover tab in the app which I don't seem to have. Does anyone know how to disable this feature?
7 REPLIES 7
Message 1 of 8
Open App -
Tap on "Activity"
(bottom of screen)
Scroll to bottom of page and tap -
"Unlock more activity"
You should then see -
"Ad Blocks"
Message 2 of 8
Where is says advanced security tap that. There is a menu behind this.
Message 3 of 8
Hi. I don't seem to have the ad blocking option shown in the screenshot so I have still not managed to resolve it.
Message 4 of 8
Hi leebitton,
How are you getting on, has fr8ys and fergusons advice helped?
Message 5 of 8
Just tap on Ad Blocking on the home page of the eero app:
Message 6 of 8
Hi thanks for your reply. I did as you said and the toggle switch was labelled Advanced Security which I toggled off but it made no difference unfortunately. It says that Ads are blocked for the network when looking at the content controls on one of the profiles.
Message 7 of 8
On the first page of the app, scroll down to security then advanced security, then Network control and toggle the switch there.
Hope this helps.
NB the TalkTalk interface differs from the Eero standard interface.
