Extending range
Snowcats
Message 10 of 10
I have just upgraded to full fibre 500, what is the very best equipment to extend the range around my 4 bed house.
I am paying for the speed so I might as well have it all round the house.
thanks
9 REPLIES 9
Message 1 of 10
Hi @Snowcats
Thank you 🙂
I have sent you a Private Message.
Message 2 of 10
i have updated me details. 🤔
Message 3 of 10
Hello again,
  • Name
  • Telephone number or Account number
  • Alternative contact number
Message 4 of 10
I'm just sending you a Private Message.
Message 5 of 10
Hi, just the one you sent me with the upgraded broadband.
Message 6 of 10
Hi Snowcats,
Thanks for your post. Just to confirm, how many eeros do you have please?
Message 7 of 10
OK, it may well be worth running some WiFi diagnostics to see if you are suffering any major interference from other networks locally. Having said that, the eero is very much designed to operate as part of a mesh system, so an additional unit may prove helpful. You can contact customer services directly to discuss this. Otherwise the support team here should pick this up tomorrow and advise further.
Message 8 of 10
Yes sorry, using the pro6 I was sent which is downstairs. Speeds in the other rooms at the moment is 80mbs. So need some sort of extenders, wanted to know what I should use and how many?
Message 9 of 10
You don't say what kind of speeds you are getting now, or anything about where your router is set up. I presume you are using the supplied eero Pro 6 and that it is wireless coverage you are talking about?
