FTTP Packages Availability
StuMcBill
Message 3 of 3
I am considering moving to TalkTalk for my broadband.  I'm currently on a FTTP connection with BT (Halo 3 - 500Mb), so am on the openreach network.
I'm considering the move to TalkTalk so I could effortlessly integrate the supplied Eero 6 Pro into my existing Eero 5 mesh network.
However, I wish to stay at either 500Mb or 1000Mb, but when I put my postcode into the TalkTalk checker it only gives me Fibre 150 as the fastest available package?
Is there anyway I can unlock the higher speed packages, as my line is suitable for it.
(As as aside, what happens with the Eero at the end of the contract - is it yours)
Thanks,
Stewart
Arne-TalkTalk
Message 1 of 3
Hi StuMcBill
I would suggest calling the sales team in this instance.
They will be able to see what options are available for your address
Gliwmaeden2
Message 2 of 3
The Eero is locked to Talktalk's service so would need to be returned if you left, @StuMcBill.
Just because a higher speed is available with another provider doesn't mean that Talktalk would have capacity for it at the moment.
