Faulty Router ?
MerseyRayUK
Message 139 of 139
I have just swapped over to Full Fibre 500  (Took just over 3.5 months from initial install date) and was first told I would be getting the super duper eero router.   Now that my install date came I received a router in the post... not an eero
I got the TalkTalk Wi-Fi Hub 3 with Firmware Version: SGEK10004A00
After around 100 minutes, the internet stops working.
Looking in the router admin panel, the connection still says its connected, but it just isnt working on any device, wired or wireless.
So I have gone to the logs in the router to see if that helps and I see the following (See pics)
It looks like somebody has been having problems with this router in 2013. Im guessing its then been sent back to talktalk for a replacement and they have sent me this faulty router.
The only way to get the internet working on my devices again is to restart the router, it works for around 2-3 hours and then the same error happens.. All devices yet again dont work, and the router light is still lit and says connected in the router admin panel.
The majority of the errors are pointing to the DNS resolution failing.  I checked in the DNS settings and somebody had entered 192.168.1.1 as the DNS server, which is the router IP so wouldnt achieve anything..  I have removed that IP and the error is still there.  This leads me to believe that the last person was experiencing the same issue that I am now getting.
Screenshot 2025-08-04 at 21-09-11 TalkTalk.pngScreenshot 2025-08-04 at 21-23-08 TalkTalk.png
138 REPLIES 138
Message 101 of 139
@MerseyRayUK, they are separate support channels, so they won't be following this thread.
Awful when these support calls are silent - they are just tickboxing. Shocking practice!
Message 102 of 139
OK so I have now factory reset the router and both channels are enabled. My macbook is still connected at 2.4Ghz, and the router is still saying that no devices are connected wirelessly.  ( All wireless devices did show here before yesterdays interactions with "Tech Support" at TT.
MerseyRayUK
Message 103 of 139
Here is the internet speed test on my iphone, connected wirelessly to the 500Mbps service.
https://streamable.com/wti5gh
Message 104 of 139
And I have just had a call from TalkTalk CS which I was expecting. I answered the call and it was silent.  Im hoping they are reading this and ring me back because that is the call that is supposed to be arranging the replacment router
Message 105 of 139
Hi Keith,
Thanks for your reply and any guidance.
On this old router, all devices (Macbook and 2 iPhones) are connecting to the WIFI 5Ghz but only connecting at 2.4Ghz.
I did a full reset last night thinking there may have been a bug after the Tech guy done his reboot/upgrade.
I totally understand it depends on the environment but this speed decrease only happened after the Tech guy done something yesterday.   I only noticed when using Airplay from the phone (around 3 metres away) to the TV (Connected via Ethernet), it was stuttering to the point that I couldnt use it.  This was obviously due to the speed of the wifi connection and not the full fibre service.
I then started to investigate and found that the macbook was connecting at 2.4Ghz, and not 5Ghz, even though the name of the wifi connection is the one that is on the 5Ghz channel in the router settings.
So I done an internet speed test on the macbook and phone, both showing no more than 30Mbps, and sometimes during the test was dropping to under 1Mbps.
The same test on devices connected via ethernet are perfectly fine at 500Mbs d/s and 70Mbps u/s.
And since the Tech guy updated something, all the devices that are connected wirelessly, of which there are quite a few, are now not showing in the "Connected wifi devices" on the router.   They are now showing the wireless devices as being connected on the wired connection.
Personally I do think this is an issue to the firmware, maybe the tech guy tried flashing this old router with the new routers firmware ?
I will however, do a full reset again now on the router and see what you may be able to help with.
Thank you.
Message 106 of 139
@KeithFrench
It's essentially that a technician has fiddled around on support and mucked up the old router that was working perfectly fine for @MerseyRayUK until yesterday.
Probably NOTHING should have been done while the customer was using their old working router.
The NEW router has never appeared to have worked. An engineer had previously visited and agreed it needed replacing.
Message 107 of 139
Hi @MerseyRayUK
@Gliwmaeden2 has asked me to help you. This is a long thread and I have only glanced at some of the posts, so I may well have missed some things.
If you have disabled any WiFi bands on the Sagemcom WiFi Hub, then due to a bug it will require a factory reset to bring it back to being as it should, despite what the UI will show. All of the DNS entries in the logs can be ignored, that is down to a bug in their classification as Error. I reported both of these bugs a while ago.
From what I can see, the problem is that your MacBook won't connect to the 5GHz band, is that correct?
Please factory reset your router so as I can try and see why you can't. Slow speed, intermittent dropouts, breaks in the signal or no signal on some or all devices or no internet access might be caused by Wi-Fi interference from other local networks, which can also lead to a permanent reduction in speed. No ISP can be responsible for your local environment; this is mainly a byproduct of the popularity of Wi-Fi.
Generally speaking, the 2.4GHz band suffers a lot more from interference than the much faster 5GHz band, but the 2.4GHz band can sometimes have a better range; however, this all depends on your local area.
In other words, I offer a free, impartial analysis of your Wi-Fi network and will try to help you optimise your Wi-Fi connection. The next stage involves sending out a guide to help you get me some important diagnostic results so that I can analyse them for you and recommend changes to your router configuration to solve them.
Message 108 of 139
And the wifi on my macbook now shows 2.4Ghz... Im currently sat around 3 metres from the router
And I have selected channel 100 but the router is ignoring that.  Channel 11 is not a valid 5Ghz channel.
Message 109 of 139
I have no idea, maybe a communication error as the Tech guy said he is in India, he was a pleasant guy and we was on the phone for maybe 30 minuted.
I told him multiple times that I was using the old router, and when I was on with him it disconnected and I asked if he had done something to disconnect me and he said he just reset it to factory defaults.   I had already told him I had done the factory reset on the new router.
Now all devices it seems are connected using 2.4Ghz, even though I have disabled that.
And the router doesnt show any wireless devices connected to it, so theres definately a fault there now after what he did.
Message 110 of 139
Why were any changes made while the old router was on there, @MerseyRayUK?
That had been working perfectly fine - did you explain that you were in touch with them using the old router?
@KeithFrench may be able to advise you - it sounds like they made changes to your network that should only have been tried if they were experimenting with diagnostics for the new router?
MerseyRayUK
Message 111 of 139
Now after open reach came out to confirm the new router was faulty, I spoke with a TT tech guy.  He done something to the router (Old router) to make it reboot.  I don’t know if it was firmware related. But it has messed up the WiFi connection to the router.  I have tried a hard reset and it doesn’t fix it.
LAN Devices are working fine at 500Mbps down, but all WiFi devices are terribly slow now
Message 112 of 139
@MerseyRayUK, I've removed the image from post 26 as it displayed your full real name - it's tucked up the top, but you'd need to edit it out and edit the image back into your post if you want to display the rest.
Staff are back on here from Monday.
Message 113 of 139
Look how long this has been going on for..
I got my contract documents for this full fibre 27/03/2025
Message 114 of 139
OMG, this is beyond ridiculous now.
The BT Openreach engineer has been today, and he agreed that my cabling is perfectly fine and the 500mb services is working fine using the OLD router.   He said he will put it down to being a faulty router.
Yesterday, Talktalk said they had scheduled a call back to me around 2/3pm so they could discuss the problem after the engineer had done his report.
Now I have just received this message saying that the problem is resolved.
NO IT IS NOT RESOLVED.   I HAVE NO PHONE SERVICE, WHICH I AM PAYING FOR, AND CANNOT USE THE NEW WIFI6 ROUTER.
Message 115 of 139
In addition to this, I want to apologise for any inconvenience and difficulties that this may have caused to you @MerseyRayUK
Message 116 of 139
Yes thats what they are coming for.
I know its the router though, just another day to wait till they are allowed to look at sending me a replacement.
I have done all the check possible here.  (I used to be one of the better Qube GB engineers installing TalkTalk Fibre and TV services for people.)
So once again, im back on the old router, connected to the Full Fibre and having no problems.  Just missing a phone line now
Message 117 of 139
I hear your concerns @MerseyRayUK and thank you for confirming with feedback. I understand that since the team scheduled an engineer appointment for this matter it will come to your home and check on everything.
Message 118 of 139
Ok,
So I called TT and eventually got to speak to a person (after 3 attempts at pressing buttons and speaking to AI)
They got me to connect the TT 3 router and they ran tests.
The line showed no fault at all and everything passed.  I was then told to keep to new router on and a call will be scheduled back in 3 hours (Thats the usualy time that the router works for), and if it disconnect before 3 hours then I was to ring them back.
15 minutes later, in the middle of a game on the xbox and im disconnected.
Checked other devices to rule out the xbox being the problem.  Sky, Firesticks, Hive Heating, Macbook, Mobiles and more are now not working online.
Rang them back and they cant send me a new router, even though the fault is pointing at that, because I have only just received this routher.
 So now they are now sending out another OpenReach engineer to check that it is the router and not the outside/inside connections.
Bearing in mind, the old router is working perfectly on this exact setup so its obviously not the cabling.
Im currently at 116 days since initial install.. TT told me im getting £6 something per day as compensation due to delays so there is something to look forward to I suppose.
Message 119 of 139
Pleasure. We will available be available for assistance should you be in need. Otherwise, do enjoy your day 🙂 @MerseyRayUK
Message 120 of 139
I will give them a ring at 9 when they open.
Thankyou.
