Fibre 150 and voice package
rab1949
Message 4 of 4
Today I upgraded my broadband and phone to fibre 150 and voice package.  The advisor told me that I could still keep my landland as I use my phone a lot
Can anyone advise if this is the case as I have read somewhere that you lose your landland with this one which concerns me.
3 REPLIES 3
Arne-TalkTalk
Message 1 of 4
Hi @rab1949
You have been on VOIP since 2023 so the only change will be the speeds.
Gliwmaeden2
Message 2 of 4
Don't confuse "landline" with "TalkTalk number" @rab1949.
If it's possible to order VOIP with your Full Fibre order, go for it. So ask to keep your TT number with VOIP.
If you hang onto a copper "leave behind" option, it can require longer downtime to upgrade later.
Message 3 of 4
If you have specifically ordered a Full Fibre with VoIP package then your landline number will simply be switched from a copper to digital service.
Anonymous User
