Fibre 150 not reaching all rooms
AmyLocks
Message 13 of 13
This is really overdue as the Fibre installation was complete in July. We had the problem then but as the rooms were barely used, it didn't matter. However, now they're in regular use, the lack of signal has become an issue.
We've tried moving the router but it seems like it's already in its optimal position.
I know there are boosters but wanted to check first if there are any other solutions or suggestions.
12 REPLIES 12
Message 1 of 13
Hi @Debbie-TalkTalk
You're very welcome.
Message 2 of 13
Hi AmyLocks
I'm so glad to hear this 🙂
@KeithFrench  Thanks for your help 🙂
Message 3 of 13
You did well, they do normally make a charge for these.
Message 4 of 13
I called talktalk and to their/your credit, the agent, service and offer (free of charge booster) were all excellent.
Thank you.
Message 5 of 13
Hi @AmyLocks
Having checked your analyser screenshots and considering the location of your Eero within your property, I agree with you that this is a simple coverage issue, which can only be solved with an additional Eero node to form a mesh. You will probably need to contact the Loyalty dept (direct number: 0345 1725157) to get one if you can get an acceptable deal.
Hi @Debbie-TalkTalk - for your information.
Message 6 of 13
If you would like to send me screenshots from the analyser, I will look at it for you, in case I can see anything. Please feel free to PM them to me if you prefer.
Message 7 of 13
I assume you mean how many eero units/devices I have. If so, just the one. If it's hardware version you're after, I'm not sure. I'm looking at the eero app and I can only see a software version which is 7.01
Message 8 of 13
AmyLocks
Message 9 of 13
Hi - thanks for your responses.
I have one of the free wifi analyse apps and it doesn't have any overlap with other devices.
It's not intermittent, there are two cold spots in the property where the signal drops which makes sense as they're the furthest from the (eero) router.
Message 11 of 13
Slow speed, intermittent dropouts, breaks in the signal, no signal on some or all devices or no internet access might be caused by Wi-Fi interference from other local networks, which can also lead to a permanent reduction in speed. No ISP can be responsible for your local environment, this is mainly a byproduct of the popularity of Wi-Fi.
If you would like me to help you, please can you specify the make/model of TalkTalk router that you are using?
Message 12 of 13
Hi AmyLocks
Can I just check, are you using the WIFI hub?
@KeithFrench provides really good advice on helping to improve wireless performance. Could you help please Keith?
