10-02-2023 05:58 PM - edited 10-02-2023 06:01 PM
We were switched to FTTP (Cityfibre) FoC but now can't upgrade the faster speeds due to a 'problem' between TalkTalk and Cityfibre. Call centre has been pretty vague about the issue. Is this a real thing and when will it be fixed?
on 18-05-2023 02:06 PM
Its down to city fibre, im sure that they are aware of this and will be working towards a solution.
on 16-05-2023 02:34 PM
Is there any actual move to fix this? It is a huge omission in the service and quite frankly tells me I should probably look at alternatives having been with TalkTalk for years.
on 11-05-2023 09:39 AM
No change I'm afraid regrades on City Fibre still require a cease and re-provide.
on 10-05-2023 11:34 PM
Recently I have seen the same advice being given out, @Strokkur.
I'll re-escalate this thread for you, for staff to give you the latest on this.
on 10-05-2023 10:17 PM
Has this situation changed at all? We are now 3 months later
on 13-02-2023 12:27 PM
Sadly its days, it appears city fibre use different processes to openreach where the profile has to enabled manually, there is an ongoing discussion to try to simplify this.
on 13-02-2023 11:42 AM
Thanks for responding.
Seems a bit of an amateurish service.
Is loss of service a few hours, a day, days?
on 13-02-2023 11:02 AM
Hi Strokkur
Regrades with city fibre can only be done by ceasing the service and reordering the higher speed , this will unfortunately mean a loss of service while the new order is processed.
Sorry.
