Full Fibre 150 installed yesterday
Barrowman
Message 31 of 31
Hi folk, I hope someone can help this 79 year old understand why when I had fibre 65 copper wired to my house I had better wifi all over the house than I do now I have full fibre.
Yes I do have 150mb download speed in my lounge but everywhere else it drops down to it's lowest reading of 1.4mb in my conservatory where my wife sits in the afternoons. With my fibre 65 I used to get around 32mb speed in the conservatory - now it's virtually nothing and makes it impossible for her to watch anything.
Any comments appreciated, thank you.
Barrowman
30 REPLIES 30
Barrowman
Message 1 of 31
Thank you Ferguson.
No I Have'nt.
I've just tried that with my seven year old laptop but I guess thats not up to the job, it only recorded 38Mbps. I don't have a
phone port on my laptop so I will get my son to come over again with his newer laptop tonight hopefully, and we will do
another wired test.
Thanks again for your intervention...   Kind Regards
Barrowman
Message 2 of 31
Have you tried a wired test directly connected to the ONT i.e. bypassing the eero completely?
Barrowman
Message 3 of 31
If as you say your tests there have proved okay then its obvious to me the fault must be in my home so, if the fault lies
in my eero or the wall box it's connected to or any associated wirering then I have to pay for it.
I've an idea - I cannot afford to pay for an engineer visit so lets just forget about it and I'll just put up with it untill my
contract finishes,
Goodbye.
Barrowman
Message 4 of 31
Engineer charges will only apply if there is no fault, and it is the customers own equipment that is at fault, or something within the home.
Barrowman
Message 5 of 31
I don't understand what your saying, tested with my old hub and with two eero's, I've returned my old hub (router) to you
as requested so all my tests have been through eero's.
I've now got four speed test apps and not one of them is giving me anything like it should be.
With regard to an engineer call, is this going to cost me as I cannot afford to pay for it?
Barrowman
Message 6 of 31
As tests are passing here, and you have tested with different equipment including your old Hub and 2 eero devices, the next option is to progress towards an engineer.
Would you like to arrange this ?
Barrowman
Message 7 of 31
Morning back to you.
It was a wired test onto the eero router...
Barrowman
Message 8 of 31
Thank you for the update. Can I just confirm, was this a wired speed test directly at the ONT with the router removed or a wired speed test at the router?
Barrowman
Message 9 of 31
Hi Karl
Okay, I had my son come over this evening and we carried out wired test four times over a period of one hour, the results
were between (download speeds) 38 Mbps and the best was 81 Mbps. The upload speed since having fibre have been
a constant 28/29 Mbps which is roughly double what I had with the copper cable.
It just makes no sense that for the first week of having fibre it was a constant 150/151 Mbps.
Regards.
Barrowman
Message 10 of 31
This could be a limitation of wireless, or the speed of the wireless receiver in your devices.  Do you not know anyone nearby that could help you test wired, with a laptop etc ?
Message 11 of 31
Okay, I've turned everything off for 45 minutes and done four speedtests and its now steady in the 80's Mbps but that is still
a long way short of the 150 Mbps I should be getting on my new package!
There doesn't seem to be a problem with the upload speed, this has remained a constant 29 Mbps since fibre was installed
it's just the downlosd speed that has dropped significantly.
Barrowman
Message 12 of 31
The ONT is the little box with the lights on that Openreach installed. It will usually have labels such as LOS , PON, etc on the top.
The main light to worry about is LOS (Loss Of Service).  If this ever turns red, then there is a fault outside.
Barrowman
Message 13 of 31
What is an ONT?
Barrowman
Message 14 of 31
Can you power off all equipment for 30 minutes, including the ONT, to reset the session.
Barrowman
Message 15 of 31
So the question is, what can we do about this?
Barrowman
Message 16 of 31
Yes, speed tests sites are a little like weather reports, they all differ slightly 🙂
Barrowman
Message 17 of 31
Thank you for that info Karl.
As a matter of interest I have just done another speed test on Sam Knows, 37.3 Mbps and also on TT, 33.3 Mbps. I also use Ookla
and that showed 41 .03 Mbps so there's not a lot between them.
Barrowman
Message 18 of 31
No Problem.  Speed issues can be so difficult to pin down. You have to remember, there are actually to sides to the system, so when troubleshooting speed issues, we have the speed to the router, so thats the speed down the line to your home, then there is the speed from the device (router) to your device, phone, laptop etc.
This is why we often ask to test a wired connection to see if the speed being delivered is correct.
But it doesn't stop there, speed test sites themselves can vary, so it's always good to try a couple.  Sam Knows is usually as reliable as most.
Barrowman
Message 19 of 31
Morning Karl.
I’ve tried Sam knows Speedtest and the results were a bit better today.
96.7Mbps 96.5, 97.6, 77.7 and 92.6.
Unfortunately I don’t know how to do a wired connection as I don’t have a suitable cable, I can’t see where to plug it into on eero or my laptop if I had one anyway.
 I’m having to post this using my phone as I have only been able to login on my laptop once today it keeps saying “unable to access this information please try again later”.
Thank you for your patience with this 79 year old fella.
Barrowman
Message 20 of 31
Can you try some wired speed tests via Sam Knows Speedtest
See how these compare to speed tests over wifi, to see if it is a wifi issue.
