on 17-01-2025 10:44 AM
I have a openreach gfast modem and the internet light is permanently out. I have software that monitors my network connection and this is a sample from that,
Date and time Status Status duration
| 17.01.2025 10:30:48 | Online | 0:08:06 |
| 17.01.2025 10:30:48 | No Internet connection. Wi-Fi/LAN OK | 0 |
| 17.01.2025 10:19:15 | Online | 0:11:33 |
| 17.01.2025 10:19:15 | No Internet connection. Wi-Fi/LAN OK | 0 |
| 17.01.2025 8:57:41 | Online | 1:21:34 |
| 17.01.2025 8:55:40 | No Internet connection | 0:02:01 |
| 17.01.2025 8:55:25 | No Internet connection. Wi-Fi/LAN OK | 0:00:15 |
| 17.01.2025 8:54:22 | Online | 0:01:03 |
| 17.01.2025 8:52:32 | No Internet connection | 0:01:50 |
| 17.01.2025 8:52:10 | No Internet connection. Wi-Fi/LAN OK | 0:00:22 |
I have had a new router TalkTalk but this problem remains. I understand that the gfast is no longer supplied. Therefore is it possible that TalkTalk can supply a replacement modem?
on 27-01-2025 07:23 AM
Hi @fizz1983
If you do experience any further issues then please let us know.
on 26-01-2025 09:57 AM
I have fitted new modem and no problem with that. My internet monitor connection app to says I have no internet for the last 13 hours, as shown by this.
I DO HAVE INTERNET CONNECTION and have had all the time so I have to assume that monitor app is at fault. I will therefore call this subject closed and return old modem to you as requested. Thank you for your help.
on 21-01-2025 10:02 AM
Thank you. I will let you know at end of week how things are.
on 21-01-2025 09:57 AM
Hi @fizz1983
The line tests are clear - no faults detected.
If the connection continues to drop (including wired connections) then the next step will be an Openreach engineer visit.
Please let us know if you would like us to arrange this?
on 21-01-2025 09:44 AM
Hi Debbie,
I have been away and found the parcel had been delivered yesterday. Whilst away and using my laptop on another system I found I was still having same issues therefore changing modem may not help.
I did a bit of research and in the end I reset the network connections on my laptop. All the time I was away I had no problems and since being home I have had 20 hours with no problems. I was going to wait a day of two before fitting new modem to see if I had solved the problem.
on 21-01-2025 09:07 AM
on 17-01-2025 12:26 PM
Hi @fizz1983
You're welcome 🙂
I will check in again with you next week to make sure the modem has arrived and everything is working ok.
on 17-01-2025 12:22 PM
Thank you Debbie
on 17-01-2025 12:14 PM
Hi @fizz1983
Thank you 🙂
I have ordered a replacement modem, this will replace your current modem and also the TT router.
Please allow 24-48hrs for this to arrive. Let us know how you get on.
on 17-01-2025 11:32 AM
Just added details
on 17-01-2025 10:54 AM
Hi @fizz1983
Please can you add your name and TalkTalk landline number to your Community Profile, I can then take a look at this for you.
