Restarting Network.
Talman
Whizz Kid
Message 5 of 5
I have tried to install an update on my Eero router, but every time I click on install now I get the circle of doom where it is stuck on restarting network.
I have done all the usual stuff unplugged it etc and when I go back into the app is says update available, and I click on install now and get stuck at the same point.
Is there anything else I can try or is my router faulty?
Many thanks Dave.
4 REPLIES 4
Message 1 of 5
Hi @Talman
That's great, thanks for letting us know 🙂
Thanks for your help @fr8ys 🙂
Message 2 of 5
Pleased to hear it worked ok.
Talman
Whizz Kid
Message 3 of 5
Hi fr8ys
Thanks for your answer! It has finally installed and restarted the network!😊
Best wishes Dave.
Message 4 of 5
I get this too. Sometimes it works if I click back then try again.
If not I leave it as it will update overnight.
The router is not faulty, just a communication issue between the app and the router when it doesn't pick up the command.
