on 18-01-2025 02:27 PM
Dues my TalTalk router failing and the fact TalkTalk have been unable to replace the faulty router, I purchased an ASUS router and have been unable to set it up. Has anyone any advice on how U do this?
The built in wizard never goes past trying to connect to Internet, and it appears no IP address is being server for the WAN connection. Any help will be grateful
on 20-01-2025 09:52 AM
Hi Darlo,
Could I just ask, what's the problem with the TalkTalk router?
on 19-01-2025 04:00 PM
Yes seen that and entered the details manually but still doesn't work. I have no dsl led showing on router when cable from ont box is plugged in WAN port on router.
No further forward really.
on 18-01-2025 02:51 PM
Have you seen this help guide?
https://community.talktalk.co.uk/t5/Articles/Set-up-a-non-TalkTalk-router/ta-p/2205383
If you have any variant of fibre I believe you follow the fibre Instructions.
Hope this helps.
Let us know how you get on.
