Hub pack faulty
Broncho
Newbie
Message 2 of 2
Power cable damaged and no prong plug receptor in new pack
1 REPLY 1
Message 1 of 2
Is this a replacement hub?
If so can you use the cable from your old one as they are interchangeable if it's like for like ( but not if a replacement for an old YouView or 4k box).
Let us know how you get on please.
You are in the staff's queue for a response.
For a quicker reply can you please ensure you have your personal information up to date in your profile including your TalkTalk landline phone number so your account can be traced. Link here - https://community.talktalk.co.uk/t5/user/myprofilepage/tab/personal-profile:personal-info
You can also add your account number in the private notes field, which only you and the support staff can view.
Please post back when done.
Thank you
