on 14-02-2024 11:43 AM
Been trying to get a response from Twitter for over an hour to understand why my connection keeps dropping every <5 mins.
Can anybody advise?
FYI - SamKnows has been taken over by CISCO and I can't find their lookup service..
on 27-06-2024 10:29 AM
Hi @McParland57
This issue has been linked to an incident that is under investigation. We will monitor for updates and post back on this thread once additional information is available.
on 24-06-2024 01:17 PM
Hi McParland57
I've asked our My Connection team to take a look at this and I will post back as soon as I have further information.
on 24-06-2024 12:55 PM
Hi Debbie
Unfortunately I don't get the time to keep chasing these little updates.
I still can't run a speed test and I still get the same update.
YEs I've tested different browsers and different devices.
on 07-06-2024 06:36 AM
Hi McParland57
Can you confirm if you have recently tested with different browsers and on a different device?
Can you also send post a screenshot of what you receive when you try and run a speed test, please remove any personal information from the image before you post it. I can then pass this to the My Connection team to take a look.
on 06-06-2024 01:52 PM
I have and i I still can't get a speed test.
on 23-05-2024 08:08 AM
How has your connection been? Did you have a chance to reboot the router?
on 21-05-2024 01:11 PM
Hi McParland57
I have checked the connection and I would suggest rebooting the router.
When did you last reboot the router?
on 21-05-2024 12:05 PM
Strange - i thought I'd replied to this over a week ago
The TV is the only one I notice on - probably because the need for streaming..
The router is upstairs, and has ethernet devices connected so not possible to move closer to the TV.
Also - still can't run a speed test at all.
on 08-05-2024 01:32 PM
Can I just confirm, is the TV the only device which is currently dropping the connection? Is the router located close to any electrical devices that may be causing inteference? Is it possible to move the router closed to the TV?
on 08-05-2024 01:18 PM
Hi Michelle
Still not able to run a speed test on either Edge or Firefox browsers.
TV, which is 4 metres away downstairs from the Router which is upstairs. , is still dropping signal occasionally. Three times yesterday during Giro D'Italia coverage. This is not as frequent with the new router as compared to the old one
on 21-02-2024 07:41 AM
Good morning,
Does the My Connection issue also happen if you use a different browser? Would it be possible to post a screenshot of what you see what this happens (please remove any personal information before posting) and we can ask the My Connection Team to take a look.
In regards to the TV, how far away is the TV from the router please?
on 21-02-2024 06:40 AM
Yes, "TV has lost connection". Luckily it does reconnect within a few minutes but it does stop what ever we are strsaming
on 20-02-2024 09:25 AM
Hi McParland57,
Do you get any message on your TV when it loses connection?
on 19-02-2024 06:55 PM
Yes I am running it that way (and it fails on different devices)
Yes, the TV actually dropped when I opened this thread, but it was fine most of the day yesterday
TV connected wirelessly
on 19-02-2024 07:29 AM
I'm sorry to hear this. Are you running the speed test via your My Connection? Is the TV still dropping connection? How is the TV connected please?
on 17-02-2024 02:34 PM
Not been able to run the speed test on my line for 3 days though. "We've run in to a problem"
on 17-02-2024 07:22 AM
Router received and up and running for 2 days. All looks ok. Only small issue I've noticed is a couple of drop outs from the TV.
Will return old one in bag next week. Thanks.
on 16-02-2024 11:55 AM
Hi McParland57
Have you received the router?
on 14-02-2024 02:42 PM
Hi McParland57
No problem 🙂
We will check in again with you once you have received the router.
on 14-02-2024 02:41 PM
Thanks for all your help chaps.
