Internet bad if different rooms of 2 bed flat
Crappyservice
Message 5 of 5
I have a 2 bedroom flat, the broadband in some rooms is very poor. Can't get Talktalk to understand the problem. Have done speed tests in each room, it comes up with "status Good" even though the speeds are so different.  Why is this and why can't Talktalk understand the problem?
4 REPLIES 4
Message 1 of 5
Yes thick was can affect wifi signal strength. If you could run a couple of speed tests on your laptop that would be helpful
Message 2 of 5
Hi Divsec,
It was done on an android phone, same one in each room.  I am not sure about 2.5 or 5 ghz.  The signal can drop off.
Would my thick walls make a difference?
I don't know ethernet speeds.
I could try later today with a laptop to do another speed check.
Chris-TalkTalk
Message 3 of 5
Hi Crappyservice,
Can you please answer Divsec's questions and we'll be happy to look into this for you
Divsec
Message 4 of 5
Hi @Crappyservice a bit more detail could really help, please.
Are the tests on the same device in different rooms?
5ghz or 2.4 ghz.?
Is the speed to the router constant?
How are your ethernet speeds?
Apple or Android.?
Looking forward to hearing.
From the 29th of March our TalkTalk Community will move to peer-to-peer support and the TalkTalk team will no longer be here to support with queries. Don't worry we still have plenty of ways to reach out if you need to speak to TalkTalk directly. For more details check out the link here: How to contact TalkTalk Broadband - Help & Support.
