on 06-04-2024 10:21 AM
Before Full Fibre I was getting approx 65 around the house in every room. Once up graded to Full Fibre I should be getting 150 but, only hitting 93 on average. This means we get as low on occasions 40. Also now having trouble picking up the signal all around the house. Why would I advise others to get talktalk Full Fibre. I need to get my copper wire back, this upgrade is not fit for purpose!
on 08-04-2024 08:53 AM
Hi Mr_Frustrated,
If you still need assistance can you please answer Keith's questions
on 06-04-2024 11:19 AM
No, it is not a con, but when your fibre is as fast as this, your device speed & specification can be more the limiting factor, along with the distance it is from the router. Please can you tell me what sort of device this is? Then there is the router that you are using that needs to be considered, which one do you have?
