Issues with connection dropping
Aaron_Campion
Message 9 of 9
My internet connection for the last hour has been going down for around 15-20 mins then coming back on for a few mins.
I’ve tried restarting the router however the connection went down with a couple of minutes.
i have done a line test on talk talk website which says no issues.
anyone else having issues?
8 REPLIES 8
Aaron_Campion
Message 1 of 9
Just to provide another update.
not sure if the engineer came or what he found. Internet seemed okay for a few hours but it just randomly dropped again. Connection goes off for a few mins then comes back.
I have noticed light on router stays white while there is no connection.
I have also noticed loads of errors on my router logs mentioning about DNS resolution failure. Not sure what that means.
Message 2 of 9
Hi Michelle,
thanks for the update
Message 3 of 9
I've re-checked for an update and the fault has been assigned to a Openreach line engineer this afternoon to resolve the fault. I'll check again first thing in the morning.
Message 4 of 9
Hi @Aaron_Campion
No problem. I will check on this again later this afternoon for any additional updates from Openreach.
There are no timescales at the moment but I will keep monitoring for updates.
Message 5 of 9
Hi Debbie,
many thanks for your reply. Do you know when openreach might attend?
Message 6 of 9
Hi @Aaron_Campion
The line test has detected a potential external line fault so we've passed this over to Openreach now to complete an external line investigation. We'll monitor the fault for any additional updates for you.
Message 7 of 9
I have the Sagemcom WiFi Hubs however not sure of the model number. Will check when I get home.
i tested my internet this morning and was still having issues. I have found the WiFi drops whenever u use it.
it will come back on but once u load a video or load a game the internet drops again
Divsec
Message 8 of 9
Hi @Aaron_Campion you don't mention which router you are using?
Your post has been escalated.
