Moving Digital Voice Adaptor to another eero
BobFormby1
Message 4 of 4
Upgraded recently to full/fast fibre.  The engineer left with the DVA connected to the 'main' eero device.  In order to get a decent signal strength around the house ( front garden is great btw) I have added another eero box.  I want to move the DVA to this 2nd eero.  Can I do this and if so, what is the sequence of things I need to do?
Thanks .
Bob.
3 REPLIES 3
Message 1 of 4
Morning Bob,
I'm glad to hear this and thanks for confirming 🙂
BobFormby1
Message 2 of 4
Thanks Michelle - just as you said, no need to remove and then add through the app - just plugged it in to the 2nd eero.
Bob.
Message 3 of 4
Hi Bob,
If your DVA is currently working ok then you should just be able to unplug this and connect it to the 2nd eero. Have you tried this already?
