NO CONNECTION SINCE THE 10TH MAY
Archers
Message 111 of 111
Surely someone can help me on this. Hours spent on the phone and on the online chat bots.
Talk Talk engineer booked to come out to me, he turns up, he is an independent engineer who hasn't a clue about the Eero boxes and totally wasted 2 hours of my life.
2 hours on the phone to SUPPORT wow!!! After 35 minutes of going through all the information being transferred 3 times to different people. Explaining about the lights on the Eero and the Fibre box to be asked, can I make sure they have been switched on. If you are going to employ people from a call centre please please train them.
2 hours on the phone I explained I had tried 5 different Eero units and I was not told that there is a router Eero which I should have. The engineer turned up with one he didn't know it was a router box????
Still no connection. Still annoyed...
Sky worked up until midnight on the 9th. My connection with Talk talk "Went live!!!!!!" on the 3rd, I tried then and was advised wait until your sky connection switches off and it will be ok.
Funny enough just a staling tactic. Sky switched off, Talk Talk still not connecting, still the same error. Where the Eero cannot be assigned a WAN address. Surely this is a simple fix. Your servers are not releasing an IP address to the Eero here.
Can some one with some knowledge please respond to me.
110 REPLIES 110
Message 101 of 111
Are both lines on the same account number, the one you've entered in your profile?
Message 102 of 111
Sorry just checked I have piggy backed on to my neighbours wifi.
I think you have just found the issue.
At this address there is 2 ONT numbers and 2 fibre boxes, one for the main farm house which I live in and one for the barns which my sister in law lives in.
It sounds like you have pointed my connection to the wrong ONT number
Are you pointed at the ONT that ends in 933?
Message 103 of 111
Apologies but are you sure that you are connected to the 4G network at the moment as the IP address that you appear to be posting from is the same as the one showing on our systems as the IP address allocated to your router
Message 104 of 111
I'm posting via a 4G connection I have had to set up.
I definitely have no connection via my fibre or I wouldn't be so annoyed
Message 105 of 111
OK thanks. From our side everything seems to be OK, it's showing that you have an Internet connection and IP address. Could I just ask how are you currently connected to the internet, posting on the Community?
Message 106 of 111
Yes I currently have one of your eeros Model: NO10001 connected and the lights are on the ONT and when it tries to make a connection you can see the light flash on the ONT
But the Eero app reports not able to get a WAN ip
Message 107 of 111
I'm sorry, I'm not sure what you mean about the eeros, do they have a label with the model number?
So just to confirm, you currently have an eero connected to the ONT? Which lights are on. on the ONT?
Message 108 of 111
I've just checked again this morning, I still have no connection.
When you got through the set up on the Eero app it shows that it is unable to get a WAN IP address
One question for you while I have your attention. The engineer left a smaller Eero device which is a router, when you sent the 2 Eero's to me I only received the standard type.
I am trying with the router one now, but have tried 5 different other ones, as my house is networked with them.
Chris-TalkTalk
Message 109 of 111
Hi Archers,
You appear to have an Internet connection now, do you have the eero connected?
Gliwmaeden2
Message 110 of 111
Forum staff are not back before Monday, @Archers.
Phone support for this won't be available before then.
Chat is live now, but you need to answer the initial bot questions first and then get put through.
You can do this via mobile data etc to reach them and just clear security questions.
