on 05-12-2024 06:36 PM
Advised that my ISP has not registered my IP address to enable access. I see a few others have this issue and despite contacting support they are in denial that the issue is TalkTalks 🤷♂️🤷♂️Web issue explained
on 09-12-2024 08:49 AM
Thanks for letting us know Djabz.
Ady
on 07-12-2024 09:44 AM
Exactly the same, no change
on 06-12-2024 07:03 AM
Hi Djabz,
How are you getting on, has ferguson's advice helped?
on 05-12-2024 07:04 PM
Try changing your DNS server settings:
https://community.talktalk.co.uk/t5/Articles/Using-3rd-Party-DNS/ta-p/2205279
on 05-12-2024 06:58 PM
Thanks for the suggestion but that hasn’t worked recently 🤷♂️
on 05-12-2024 06:52 PM
Try turning your router off for at least 30 minutes to enable another session which will reset your IP address.
Let us know if it works, it has for others.
