National Lottery web site access
Djabz
Message 7 of 7
Advised that my ISP has not registered my IP address to enable access. I see a few others have this issue and despite contacting support they are in denial that the issue is TalkTalks 🤷‍♂️🤷‍♂️Web issue explainedWeb issue explained
6 REPLIES 6
Message 1 of 7
Thanks for letting us know Djabz.
Ady
Message 2 of 7
Exactly the same, no change
Chris-TalkTalk
Message 3 of 7
Hi Djabz,
How are you getting on, has ferguson's advice helped?
Message 4 of 7
Try changing your DNS server settings:
https://community.talktalk.co.uk/t5/Articles/Using-3rd-Party-DNS/ta-p/2205279
Djabz
Message 5 of 7
Thanks for the suggestion but that hasn’t worked recently 🤷‍♂️
Message 6 of 7
Try turning your router off for at least 30 minutes to enable another session which will reset your IP address.
Let us know if it works, it has for others.
