Neighbours Conifer tree
demacca1
Message 7 of 7
The wire to the house runs through a large conifer tree in my neighbours garden. In these high winds the wire is being stretched from side to side quite aggressively. It looks like it may disconnect.
Whom do I contact?
6 REPLIES 6
Message 1 of 7
OK thanks. If you think there's a potential Health and Safety issue you can report it directly to Openreach here - Report damage, vandalism or a health & safety issue | Openreach
Message 2 of 7
Broadband is okay
Message 3 of 7
Hi demacca1,
Are you experiencing any problems with your broadband service?
demacca1
Message 4 of 7
Michelle - your people disconnected the phone number when we switched from Virgin so it is just the fibre that comes from a pole the other side of the tree.
Message 5 of 7
It is TalkTalk you need to contact if it breaks, but not until then or it becomes dangerous. Openreach would do the work and might be justified in saying that it is the fault of your neighbour's tree height. However, that is just my opinion & that is between you & your neighbour.
Message 6 of 7
I'm sorry to hear this. Can I just confirm, are you currently experiencing any issues with the voice service such as any noise on the line or is the broadband dropping connection?
