on 20-03-2023 04:54 AM
Hello we got upgraded from Fibre 65 to full fibre 500 and the wifi coverage from the Eero 6 pro seems to very bad and much worse than the old routers.
We have 1 PC that is approx 10 ft away that gets full 500mbs connection - This is good.
We have a second PC that is slightly further but in same room that only gets 170mbs max but more concerning for me is the laptop upstairs which is still within 15ft from the Eero pro with just a thin wooden floor separating the room cannot get a signal which means I cannot even watch a 140p video because connection is weak and keep dropping. We didnt have this much of a wifi issue with the old talktalk routers.
Can anything be done about this ? as the Eero pro 6 is supposed to have superiour coverage.
No need for a community member to respond as I know it may take time for the talktalk team to respond. Thanks
on 03-03-2024 02:55 PM
Thank you Keith. I have started a new thread here: https://community.talktalk.co.uk/t5/Full-Fibre/Upgrade-from-Landline-to-Fibre-500-w-Eero-coverage-is...
Your advice would be very welcome. I look forward to hearing from you.
Best regards
on 02-03-2024 01:44 PM
Hi @Tez2012
A lot will depend on the WiFi band that each device is using and the level of Wi-Fi interference that is present with which I can provide a lot of help with.
The next stage involves sending out a guide to you to help you get me some important diagnostic results so that I can analyse them for you and recommend changes to your router configuration to solve them.
Whilst the Eero is supposed to manage Wi-Fi interference, if this is very bad, particularly in the 2.4GHz band, then it cannot do anything about it, no router can. The same goes for any router at that point. Other things that may then need to be investigated are its location within your property and the WiFi bands that you use. It is possible that you may also need to purchase additional Eero nodes as it is supposed to operate as part of a mesh system. I can help with any of this. However, I would suggest that you follow my help to find out what the root cause of the problem is, before throwing money at it.
Hi @glide98
I can offer the same help to you, but firest you must create your own thread. Thanks.
on 02-03-2024 11:48 AM
I have just upgraded the same way. I am experiencing exactly the same issue you had. I chatted with support earlier and they said that stabalisation can take 1-2 weeks, but it is very frustrating to not be able to get any connection at all in the room directly above the gateway eero pro 6 (the one that came with the service upgrade). Can I ask you what your solution was in the end?
The whole point of upgrading to fibre was that previous service signal wasn't good enough to have decent video conference calls, so any work from home became difficult. Now it's terrible! If there is a stabilisation period then TalkTalk should communicate this clearly to customers. If I knew what to expect I would be OK, but being in the dark and then experiencing these issues and not being able to understand what is going on causes a lot of anxiety and wastes a lot of time. TalkTalk customer service should address this with clear comms to customers.
on 23-03-2023 08:51 AM
Hi Tez2012,
I've sent you a PM
22-03-2023 01:51 PM - edited 22-03-2023 01:52 PM
Hi, its mainly the devices upstairs which are still pretty close to the actual router, just above it (less than 15ft away). I have also packed the old router away along with anything else I thought may have played havoc with the Wifi coverage.
Edit: The signal seems almost none existent in the room above where the router is.
on 22-03-2023 01:48 PM
Ok thanks for confirming. Are all devices losing the connection or just the one's furthest from the eero?
on 22-03-2023 01:43 PM
Hi Michelle, just the one we received in the post for when Openreach installed the Full Fibre last Saturday. We lost our connection today too for 5 mins. Thanks
on 20-03-2023 07:54 AM
Just to confirm, how many eeros do you have?
