7 hours ago - last edited 7 hours ago
Just had fibre 150 installed yesterday I now am using the wifi hub 2 vs SGK100206.
It seems that the wifi signal is not as strong as the old hub (copper )
The day before the fibre install i did a key room and also garden test where i mostly use the internet and am now comparing the results.
At first thought that the signal/ speed was slower but I think the signal seems to be coming and going which may account for my seeing poor results on the new compared to the old, depending on the exact moment I start the sped test.
I have a wifi app that is showing me that the router is using channel 11 but this channel seems to be varying star wise from full stars - all the way down to 0 star and yet other channels are consistently stable at full stars. See screen shot from phone.
3 hours ago - last edited 50 minutes ago
Ok not done the tests yet that you needed but I have looked at the router settings and channel 1 is selected and when I click the drop down list the first option is "auto" so shouldn't the router be set to this (auto ) in order for it to use its use it's WiFi Optimisation,
I have just realised that earlier it was channel 11 but now it is channel 1 so it seems to be doing its thing and changing but according to my wi fi analyser app channel 1 is now the least best along with 11. Its like the router is picking the worst channel instead of the best.
Sitting here watching the app channel 6 and 7 are constantly the best channel - why is it not using those.
Same for the 5Ghz it is set at 108 but there is an option for "auto"
Should I just change them both to Auto. Or was it indeed on auto and the channel 1 and 108 displayed are what it has chosen. Or would it just say "auto"
5 hours ago
The problem is that both routers use WiFi Optimisation, a feature that is supposed to ensure that you are always on the best channel. You can try changing the channel, but there is every chance that WiFi Optimisation will move you back again.
6 hours ago
I will get onto the info ASAP but is there a short cut, can I just tell the router to use one of the other channels that are not so flaky.
I think am aware of the best practices with regard to the best wifi signal re- position - facing direction, glass mirrors, vases and such like, so all of that is as best s it can be.. For reference the new router is in exactly the same position as the old one.
7 hours ago
Thanks keith I will get onto it.
7 hours ago
Hi @Marvel
@Michelle-TalkTalk has asked me to help you. That screenshot is not much use. I will need to see the main AP view, 2.4 & 5GHz channels plus the signal strength/time graphs. I will also need to know your network name as well. Please PM all of this to me to protect your privacy.
7 hours ago
7 hours ago
As I understood it - I thought that the router changed its channel depending on it finding the best one but it seems to like channel 11 which looks iffy !
