No WiFi Calling on Sagemcom 5464 with v202 firmware installed
aa2000
Enlightened One
Message 20 of 20
As is the case with some other posters, WiFi Calling no longer works since the installation of v202 firmware (Samsung S23+)
19 REPLIES 19
Message 1 of 20
You're Welcome 🙂
Message 2 of 20
@Karl-TalkTalk  Yes, WiFi Calling has been restored.  Thank you.
Message 3 of 20
That should do it, test now.
Message 4 of 20
Sorry, you have 2 active routers linked to your hardware profile, I'll rollback the correct one now.
Message 5 of 20
@Karl-TalkTalk  Mine has not rolled back, still on version SG4K100202.
Message 6 of 20
Firmware has been rolled back, let me know if Wi-Fi calling is now working for you.
Message 7 of 20
Our devices team have confirmed they are going to rollback the firmware shortly.
If you do use Whatsapp, can you confirm if whatsapp calls work as expected.
Message 8 of 20
Thankyou.
Message 9 of 20
Vodafone.
Message 10 of 20
Hi @aa2000
Our device manager has also asked if you can confirm what mobile Network you are using.
Message 11 of 20
The pic should show the Wi-Fi calling icon in the status bar - here is the icon on my phone below :
Message 12 of 20
If possible, can you PM a screenshot from the phone when Wi-Fi calling is failing.  You can usually capture a screenshot by pressing the power button and volume down together.
Message 13 of 20
OK, I'll get this info to our Device manager so they can pull the logs from the router and see whats happening.
Message 14 of 20
Correct @Karl-TalkTalk
Message 15 of 20
And just to confirm, you are not making calls over whatsapp.
Message 16 of 20
Yes @Karl-TalkTalk it is One UI version 6.1.    Not making calls via Whatsapp.
Message 17 of 20
Thanks, is it also ONE UI 6.1 ?
And you are not making calls over whatsapp.
Message 18 of 20
@Karl-TalkTalk   Android 14.  Standard Mobile calls.
Message 19 of 20
Can you confirm what version of android you have, and if you are making calls over whatsapp or standard mobile calls.
