on 05-12-2024 10:29 PM
How do you get the ONT box moved. I've tried calling no help webchat terrible. Please help?
on 09-12-2024 11:30 AM
Cityfibre will also charge to relocate the socket, but their charges may vary. I would suggest speaking to CityFibre directly, but as Keith mentions, it may be cheaper to look at other options, for example running a longer ethernet cable from the ONT to the router location.
on 06-12-2024 10:30 PM
Hi @pawson
There is another way around this problem, which might be suitable & only cost you a few pounds. Roughly how far away is the ONT from where you want the router to be?
on 06-12-2024 03:41 PM
Hi Karl
Ours was fitted by city fibre not open reach ?
on 06-12-2024 08:40 AM
Hi Pawson
If you require an ONT Box moving, Openreach class this as an LVR or Low Volume Request. Average lead time for this is around 2 - 3 weeks, and they will charge £128 for this.
There may also be limitations depending on where you want it relocating, if it is not an exterior wall, if it is above a ground floor etc etc.
Do you still need this arranging ?
on 05-12-2024 10:33 PM
Why a "farce?" Was it initially installed somewhere against your wishes?
