Persistent internet outages since city fibre upgrade
on 15-02-2024 11:45 PM
Message 41 of 41
Our new full fibre line was installed on the 31st of January and since then we’ve had nothing but headache, I have reset all my gadgets and appliances more times than I care to remember and even when they reconnect its not before long that they have issues. Our old line using the copper wiring didn’t have these problems and even after contacting TT and getting them to attempt to rectify the problem this only lasted a couple of hours, it’s now got to the point that I’ve payed extra money for data on my mobile phone plan just to use the internet, as there is none persistently at home… Need some help asap, as I’m not going to keep paying for a service I’m not receiving
Labels:
- Labels:
Connection
Stability
Wifi
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
40 REPLIES 40
on 29-02-2024 01:25 PM
Message 1 of 41
Hi @ang85
I don't expect that the Netgear is faulty at all, I suspect that its configuration is clashing in some way with the Sagemcom 5464. However, as I have no idea how either has been configured, this won't be easy.
First off though, I think that you said that the Netgear is configured in Access Point mode. Looking at the user guide for it, I assume that it connects to the 5464 via an Ethernet cable or powerline adapters, not via the 5464's Wi-Fi? If so, roughly where in your property are both of these units located & how are they connected together?
I did offer to send you a guide to you to help you get me some important diagnostic results so that I can analyse them for you and recommend changes to your router configuration to solve them. Once I know the answers to my questions above, I will probably need to send this to you via a PM. Then I will need you to reconnect the Netgear for a short while, whilst I get you to gather the diagnostic information for me. Then it can be temporarily disconnected again.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 29-02-2024 11:21 AM
Message 2 of 41
Thanks for this @ang85.
I have just downloaded the user guide & I will try & get back to you later this afternoon.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 29-02-2024 11:08 AM
Message 3 of 41
Thank you for your help once again
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Message 4 of 41
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 28-02-2024 01:12 PM
Message 5 of 41
Our posts have just crossed the ether!
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Message 6 of 41
Snap 🙂
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 28-02-2024 01:11 PM
Message 7 of 41
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Message 8 of 41
Hi @ang85
Please can you give me a model number for this Netgear extender, then I should be able to answer this question?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 28-02-2024 01:08 PM
Message 9 of 41
Hi there, just an update, once I moved the hifi speaker there was still an underlying issue and I’ve managed to track it down to a NETGEAR WiFi extender/access point we have connected to some equipment as an access point.
we tested this theory several times and that seems to be the issue with our WiFi disconnecting, so we’ve just disconnected it for now.
Any ideas why that would happen?
thank you
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 23-02-2024 08:50 AM
Message 10 of 41
Hi ang85
How are you getting on, how's the connection been?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 21-02-2024 03:03 PM
Message 11 of 41
OK thanks 🙂
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Message 12 of 41
I’ll let you know what happens over the next couple of days. Thank you
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 21-02-2024 02:56 PM
Message 13 of 41
Yes try & then let me know.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Message 14 of 41
Hi ang85,
Would you like me to disable wifi optimisation or leave it until you've tested with hifi/speaker relocation?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 21-02-2024 01:58 PM
Message 15 of 41
We could trial the connection for a few days to see if it works ok, what do you think?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 21-02-2024 01:49 PM
Message 16 of 41
One of the speakers was fairly close to the hub, we had a reshuffle about the same time, the hub didn’t move but now thinking about we moved the hifi, didn’t think about it at the time as the hub and its components weren’t moved. I don’t mind disabling WiFi optimisation if you think it will help? I have in the mean time completely unplugged and removed the hifi as it was the only electrical device near the hub apart from a side lamp
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 21-02-2024 01:38 PM
Message 17 of 41
You can't enable or disable wifi optimisation yourself, only TalkTalk can do this for you. Hence why I suggested that you ask them to disable it for you in your reply. Have the problems only happened then since moving the HiFi, or more particularly its speakers, as if too close then they will cause electrical interference, rather than WiFi interference?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 21-02-2024 01:34 PM
Message 18 of 41
Haven’t touched the settings on the hub at all, just reset it tons… the only thing I just thought of was the hifi system was moved closer to the hub could this cause issues?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 21-02-2024 01:29 PM
Message 19 of 41
Thanks for that info @ang85
Have you had TalkTalk’s Wi-Fi optimisation disabled on your Sagemcom FAST5364/5464 router? When this is enabled, as it is by default, it has the power to override any Wi-Fi configuration changes that I might suggest that you need to make. This will not help rectify this type of problem if Wi-Fi Optimisation is allowed to change my suggested settings. Only TalkTalk can do this for you, you cannot do it yourself. If not, just request they disable this for you in your reply.
The next stage involves sending out a guide to you to help you get me some important diagnostic results so that I can analyse them for you and recommend changes to your router configuration to solve them.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 21-02-2024 01:27 PM
Message 20 of 41
Also just to clarify, we haven’t moved the hub since the installation of the full fibre and it’s been the same place for many years previously without much issue.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
