on 30-11-2024 01:55 PM
We had Full Fibre 150 installed yesterday. The WiFi signal now doesn't cover the whole house because the router is now positioned less centrally. I had hoped the latest TT router might do the job - but no. It's a Sagemcom 5464. What can we do to get better WiFi coverage?
yesterday
Hi Martin,
Thanks for confirming. No rush, just set up when you're ready.
yesterday
Michelle,
Thanks for asking. The new eero etc kit arrived yesterday afternoon and I haven't opened the package yet. I need a couple of days to set it up and find the best position for the extender. I'll report back when I can.
Martin
yesterday
Hi Martin,
How are you getting on?
Friday
Karl,
Many thanks. It seems a complicated solution but it's fine with me. Let's hope this works for us.
Martin
Friday
I've ordered a voip adapter and a couple of eeros to be sent out to you, and a returns bag for the Sagemcom.
If you see any emails regarding equipment charges, ignore these, these are system generated and will be incorrect.
Friday
Karl, Thanks for checking but this makes no sense. We were upgraded to Fibre 150 on 29th November 2024 - exactly one week ago. We were sent a Sagemcom 5464 so that we could use our DECT landline phone. Now our router is in a different place in our house, we desperately need to boost the Wifi signal across the house. It seems there are two options :
1. Keep the Sagemcom router and get a Sagemcom booster.
2. Get a eero, an eero extender and a Grandstream ATA for our phone....and return the Sagemcom router.
Surely option 1 is the simplest (for both TT and us) and it seems worth a try. But you say this isn't possible.
Please suggest how to proceed from here.
Martin
Friday
I've just checked your account and it is set up for eero only. This will not allow us to send any equipment other than Eero, no routers or boosters.
Our Teams will only have the option of sending an Eero.
Friday
Can someone from the support team (Michelle, Debbie or Karl) please confirm that a Sagemcom booster has been ordered for us? We're getting a bit frustrated because of the lack of WiFi in one of the rooms we use as an office. Thanks.
Martin
Wednesday
OK. No Problem.
Wednesday
Karl,
Thanks for the offer but MIchelle and/or Debbie are (I hope) organising to send a Sagecom booster for me to try (see higher up in this thread). Let's have a go at that first. If that doesn't help, then I'll be happy to swap and try a eero but I think I'll also need an eero extender plus a gadget so that our DECT landline phones will work??
Martin
Wednesday
Hi Martin,
Would you like to swap out the Sagemcom for an eero and see if the coverage is better ?
on 04-12-2024 02:22 PM
The Eero is usually supplied to higher tier packages and the Sagemcom is usually supplied to Full Fibre 150 services.
on 04-12-2024 07:29 AM
Debbie,
Thanks for checking. I was expecting an eero (because TT are advertising its benefits) but I got sent the Sagemcom F5464. It's quite difficult as a new fibre customer to understand the technology until you get the installation done and receive some kit. I hadn't realised that our landline phone made things more complicated - so I have the Sagemcom router.
Martin
on 04-12-2024 07:12 AM
Keith,
Thanks. I've read your sticky. Great advice. I'll revisit it when the booster arrives.
Martin
on 04-12-2024 07:02 AM
on 03-12-2024 10:39 AM
Please make sure you read my sticky about the latest version of this booster:-
on 03-12-2024 09:19 AM
Michelle,
That would be great! I really appreciate you picking up on this issue. Full fibre has not turned out to be quite so straightforward as we hoped....and it would be good to try a booster.
Martin
on 03-12-2024 08:43 AM
Hi Martin,
Would you like us to send a wireless booster?
on 03-12-2024 07:58 AM
Keith, Thanks. We've been experimenting over the last few days. Moving our WiFi channel to avoid the neighbours makes no difference to our ability to connect on the other side of the house. Not surprisingly, if we disable 5GHz Wifi and make our phones/tablets connect to 2.4GHz, things are slightly better in the more remote rooms. Where we were getting no 5GHz signal before, we can connect to 2.4GHz slightly more reliably and get speeds of around 10Mbps....but then the speed of devices near the router suffers. We're on Fibre 150 and get speeds 40-50Mbps on 2.4GHz near the router. I'm still certain that it's our internal walls that are the main problem. It's not a surprise - they had a big impact when the router was more central in the house before the fibre was installed.
I've hunted about in the old and new Sagemcom routers' GUI and cannot find any way to use an old router as a bridge. It looks like that isn't an option. Next job is to see what TalkTalk can offer to help us set up a mesh on 5Ghz.
Thanks for your help.
Martin
on 01-12-2024 09:00 AM
You say that you can't be suffering from WiFi interference, which can change by the minute, yet you said your neighbour is on the same channel as you. That is exactly what I was talking about.
