8 hours ago - last edited 8 hours ago
I had 150 fibre installed a few months with an eero and paid £76, I was assured it would cope with voip and reach all around the house. It never has reached upstairs with a decent stength. I bought another eero to extend the signal still didn't work upstairs in my son's bedroom with his PlayStation. So I tried buying an Alexa speaker with eero capability put it in our bedroom to extend the signal to our sons but the signal still isn't strong enough and is patchy. The eero app always shows download and upload speeds as guaranteed no surprise there. But it differs throughout the day in actual usage.
So I've paid out for the installation and over £150 for wifi extensions. I think the signal strength isn't up to it. It was just as good as this before full fibre on the copper wire connection. Except I'm over £225 out of pocket. At this rate I will not be renewing.
5 hours ago
Hi Keith, thanks for your generous input. I have the initial eero that open reach fitted on behalf of TT. I'm sure it's the first edition and not a 6. That is wired direct from the fibre cable with a Grandholme hub for our landline. I then bought another to use as an extender to reach the attic (sons bedroom) which I placed in our bedroom, so there was an extender halfway between. This gave no better signal so I was already in the process of getting an Alexa speaker so tried this in our bed room as the extender but again no better. His games on his PS4 freeze etc making them totally unplayable. We've tried the second eero up in his room to see if it's better but it's not. To answer your question about wired connections there is just the main router. Everything else is wifi. At the moment the second eero is not in use.
I hope that explains it all better for you. Any help would be appreciated.
Thank you
Leagueman
7 hours ago
I can't help with the fact that you have paid out this money. However, if I could have had the chance to help you before, I might have been able to save you wasting money. The Echo Dot has so many limitations in WiFi performance I would never have recommended that. For clarity you now have one eero 6 & one echo Dot, is that correct?
However, other factors should be investigated first. When this happens, what is the status displayed in the app for the internet connection? Do you have any wired connections & if so, how do they perform?
Whilst the eero is supposed to manage Wi-Fi interference, if this is very bad, particularly in the 2.4GHz band, then it cannot do anything about it, no router can. The same goes for any router at that point. Other things that may then need to be investigated are its location within your property and the WiFi bands that you use.
